[gdal-dev] mosaicking is very slow
jratike80 jukka.rahkonen at maanmittauslaitos.fi
Mon Jan 27 02:48:32 PST 2020
I would suggest to remove --config GDAL_CACHEMAX 8000 first. Then I would
check if the source images are tiled. If they are not it could be worth an
extra step to make tiled copies.
-Jukka Rahkonen-
Simon-4 wrote
> Hello everyone,
> I am stiching aroung 100 geotiff images each of around 4gb. However,
> translating the vrt file into geotiff is going on for days.
> gtranslate --config GDAL_CACHEMAX 8000 -co TILED=YES -co COMPRESS=LZW -co
> BIGTIFF=YES infile.vrt outfile.tif
> How can I speed up it?
> Thank you.
> Simon
> gdal-dev mailing list
> gdal-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
