[gdal-dev] Coordinate space to pixel space with image rotation in python
Even Rouault even.rouault at spatialys.com
Tue Jan 28 09:30:32 PST 2020
Nicolas,
> It's easy to go from coordinate space to pixel space in python using
> something like.
> pixel_x  =  int(-124114.3  -  geo_transform[0])/geo_transform[1])
> What is the trick when there is an image rotation?
Compute the inverse geotransform with
https://gdal.org/api/raster_c_api.html?highlight=invgeotransform#_CPPv419GDALInvGeoTransformPdPd
(gdal.InvGeoTransform(gt) in Python )
And then use the coordinates in coordinate space as the input for this inverse geotransform
column = inv_gt[0] + X * inv_gt[1] + Y * inv_gt[2]
row    = inv_gt[3] + X * inv_gt[4] + Y * inv_gt[5]
> Also, as a second
> very beginner question, what is the difference between geo_transform[2]
> and geo_transform[4]?
There are defined by the relationships at
https://gdal.org/user/raster_data_model.html#affine-geotransform
Even
http://www.spatialys.com
