[gdal-dev] Python Wheels for gdal
Even Rouault even.rouault at spatialys.com
Thu Jan 30 05:41:07 PST 2020
> Maybe having libgdal and gdal as separate wheels could make sense if no one
> solution can be found?
I see in
https://pip.pypa.io/en/stable/reference/pip_install/#install-no-binary
a --no-binary switch that is apparently to not install wheels. So probably a
single pip package could be use for both use cases. Comments for people
experienced with that welcome.
> I have no overview over the licenses of the dependencies.
> Is there an overview available?
An easy way is to start at
https://packages.debian.org/sid/libgdal26
And clicking on each of the listed dependency to display its license
information (in the right part)
> Would limiting ourselves to permissive FOSS licences remove any important
> features?
The main GPL dependency I think of is the Poppler one, used for the PDF
driver.
http://www.spatialys.com
