Thanks for the information. ID is very common attribute which will be used in features representations. It would be good, if you provide a workaround or solution in next release or future release. Thanks again. Regards, Rajesh -- Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
