[gdal-dev] MSG-CPP satellite projection to wgs84 with gdal
Tibor Szabo
szabot.hu at gmail.com
Thu Jul 16 23:13:59 PDT 2020
Hi Even,
Thank you for your quick answer.
I have tried many variants in the syntax and I got output nc file only with
the following:
+proj=geos +lon_0=0.000000 +lat_0=0 +h=35807.414063 +a=6378169 +b=6356583.8
+units=km
One error msg was also remains:
szabot at manicminer:~/gdal_knmi_test$ gdalwarp -of NetCDF -s_srs "+proj=geos
+lon_0=0.000000 +lat_0=0 +h=35807.414063 +a=6378169 +b=6356583.8 +units=km"
-t_srs EPSG:4326 -te 0 50 10 60
NETCDF:"SEVIR_OPER_R___MSGCPP__L2__20200713T081500_20200713T083000_0001.nc":cot
TEST_MOD_COT_NL.nc
ERROR 5: OSRCalcInvFlattening(): Wrong input values
Creating output file that is 3125P x 3125L.
Processing
NETCDF:SEVIR_OPER_R___MSGCPP__L2__20200713T081500_20200713T083000_0001.nc:cot
[1/1] : 0Using internal nodata values (e.g. -1) for image
NETCDF:SEVIR_OPER_R___MSGCPP__L2__20200713T081500_20200713T083000_0001.nc:cot.
Copying nodata values from source
to destination TEST_MOD_COT_NL.nc.
ERROR 1: Too many points (529 out of 529) failed to transform, unable to
compute output bounds.
Warning 1: Unable to compute source region for output window 0,0,3125,3125,
skipping.
...10...20...30...40...50...60...70...80...90...100 - done.
BR
Tibor
Even Rouault <even.rouault at spatialys.com> ezt írta (időpont: 2020. júl.
16., Cs, 21:18):
> On jeudi 16 juillet 2020 21:00:40 CEST Tibor Szabo wrote:
> > Hi All,
> > I have tried to wrap a netcdf file for changing projection from satellite
> > view to EPSG:4326 with gdal_warp in Ubuntu and windows also with error.
> > Sample file:
> https://z003.s3-us-west-2.amazonaws.com/SEVIR_OPER_R___MSGCPP__L2__20200712T
> > 220000_20200712T221500_0001.nc D:\meteo_model>gdalwarp -of NetCDF -s_srs
> > "+proj=geos +lon_0=0.000000 +lat_0=0 +h=35807.414063 +a=6378.169
> > +b=6356.5838" -t_srs EPSG:4326 -te 0 50 10 60
> +a and +b values must be expressed in metres, not kilometres.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200717/86010770/attachment.html>
