[gdal-dev] Discussing DTM compression in GeoTIFF
Andrew C Aitchison andrew at aitchison.me.uk
Thu Jul 23 03:10:23 PDT 2020
On Thu, 23 Jul 2020, Andreas Neumann wrote:
> I was reading through
> https://kokoalberti.com/articles/geotiff-compression-optimization-guide/
> (very interesting article) and I am wondering about how to interpret
> read-speed vs compression. With this article I learned about the
> relatively new zstd compression and LERC, which is esp. interesting for
> LIDAR/DTM data in float32.
> In general, when you compress more, the read-speed decreases. So an
> uncompressed file would read very fast. But isn't this gain in read
> speed at the expense that you have to read a substantially higher amount
> of data when you use uncompressed or low-compressed data?
> E.g. in the table
> https://kokoalberti.com/articles/geotiff-compression-optimization-guide/read_results.png
> when you read a float32 dtm with zstd compression, predictor 3 and
> zstd_level 9, it shows a substantially lower read rate compared to
> predictor 1 (not optimized for float32). But given that predictor 3
> compresses substantially better than predictor 1 for float32, isn't the
> read-rate "overall" just as good with predictor 3?
> Formulating my question different: isn't the read-rate at
> a bit distorted by the fact that higher-compression means that you also
> have to read substantially smaller file sizes? Shouldn't this table with
> the read-rate be kind of "normalized" with the file sizes it has to read
> for exactly the same data?
> Currently, it just lists MB/CPU-sec.
I agree that the amount of compressed data to be read back is important
in this sort of analysis.
The "read" test code (from
https://github.com/kokoalberti/geotiff-benchmark/blob/master/gtiff_benchmark.py
) is
         # Run the read tests on the just created file by decompressing
         # it again.
         print("READ test: Running on file '{}'".format(option+'.tif'))
         read_file_output = os.path.join(tmpdir, 'read.tif')
         cmd = ['gdal_translate', '-q', option_file, read_file_output,
                '-co', 'TILED=NO', '-co', 'COMPRESS=NONE']
         try:
             task_clock = perf(cmd=cmd, rep=args.repetitions)
             speed = (1/task_clock) * base_file_size
             print("READ test: Completed {} repetitions. Average time: {:.2f}s Speed: {:.2f}Mb/s".format(args.repetitions, task_clock, speed))
         except Exception as e:
             print("READ test: Failed!")
             task_clock = ''
             speed = ''
         finally:
             results.append('{};{};{};{};;;;{}'.format('read', filename, option, task_clock, speed))
The line
says that the size of the original uncompressed file has been used to
calculate the speed. Since the benchmark code, appears
to be timing reading the compressed data from disk(cache), the
decompression and writing the decompressed data to disk(cache),
this is what you want for an overall performance comparison.
However, the comment
suggests to me that they will be cached at some level and will
probably still be in memory somewhere (eg filesystem cache),
unless the python benchmarking system know how to invalidate these
caches ...
The compression method that gives the best decompression performance
will depend where the compressed data is currently held;
if the file will be decompressed once from internet the compressed
size may be much more important than if there are many partial
decompressions from in memory data.
Back in the 1990s I remember hearing that some decompression
method actually used fewer instrucions than reading the uncompressed
data from disk.
Machine hardware may also make a difference.
Once upon a time the X server on Sun workstations had two
implementations of each primitive, one where memory was faster
than compute and one where compute was faster then memory.
The installer benchmarked each primitive and selected the one
which was faster on the particular machine.
Since then CPU speeds have increased much more than RAM speed,
so there may be a definite winner on current hardware, or it may
mean that the balance point allows more complex decompression algorithms.
Andrew C. Aitchison                      Kendal, UK
