[gdal-dev] Specify data type on opening a netcdf
Federico Gianoli
alpacagis at gmail.com
Fri Jul 31 08:01:46 PDT 2020
Thanks Even,
If I look at the metadata of my netcdf, the values of "offset" and "scale
factor" are in float64 instead of float32. So the correct values to read
should be -0.08 as offset and 0.004 as scale factor.
If I open the netcdf in SNAP, for example, I am able to correctly see this
information. So, I suppose that, by default, gdal reads metadata values in
float64 instead of 32bit, and I would like to know if there is a way to
force gdal to read these values as float32.
NC_GLOBAL#title=10-daily Normalized Difference Vegetation Index 333M:
GLOBE 2020-06-21T00:00:00Z
NDVI#add_offset=-0.079999998
NDVI#flag_meanings=Missing cloud snow sea background
NDVI#flag_values={251,252,253,254,255}
NDVI#grid_mapping=crs
NDVI#missing_value=255
NDVI#scale_factor=0.0040000002
NDVI#valid_range={0,250}
NDVI#_FillValue=255
Band 1 Block=3270x1272 Type=Byte, ColorInterp=Undefined
NoData Value=255
Offset: -0.0799999982118607, Scale:0.00400000018998981
Metadata:
grid_mapping=crs
long_name=Normalized Difference Vegetation Index 333M
missing_value=255
NETCDF_VARNAME=NDVI
valid_range={0,250}
_FillValue=255
Il giorno ven 31 lug 2020 alle ore 15:37 Even Rouault <
even.rouault at spatialys.com> ha scritto:
> On vendredi 31 juillet 2020 15:04:45 CEST Federico Gianoli wrote:
> > Dear all,
> > I have an issue opening a netcdf with gdal. I should declare the data
> type
> > of my raster in gdal.Open().
> > The Netcdf data type is declared in the metadata as "Float", but GDAL
> reads
> > this information as Float64 and not as Float32. This reading error
> > misinterprets my decimal values causing rounding errors.
> > float 32 to float64 (wrong):
> > [0.9160000518, 0.920000052] > 0.92 --> [False, True] WRONG
> > flaot32 to float32 (correct):
> > [0.916, 0.92] > 0.92 --> [False, False] CORRECT
> > Is there a way to specify the input data type?
> No. What do you mean by "The Netcdf data type is declared in the metadata
> as "Float"" ? Is this some text attribute that would override the native
> data type, which would be Float64 ? the GDAL netCDF driver has proper
> support for both Float32 or Float64 based on the data types of variable.
> If you need to override it, your best option is to use the -ot Float32
> switch of gdal_translate to down cast.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200731/cef0a32d/attachment.html>
