[gdal-dev] Creating Geotiff is slow
Even Rouault
even.rouault at spatialys.com
Tue Jun 16 08:37:49 PDT 2020
> I am puzzled by this behavior... Is there something wrong with my GDAL
> settings ?
> Is there a way to speed up the GeoTIFF creation ? Why is it faster using
> python ?
There might be several factors:
- if with rasterio you read completely the image into memory, and then write it, parallel
decompression is perhaps more effective. gdal_translate (actually the mechanics behind it)
tries to use smaller read & write windows by default. You could try to set the
GDAL_SWATH_SIZE configuration option to 250000000 so that the full band is read at once.
- but I suspect the reason might be due to the Sentinel2 band reporting 15 bits, and
gdal_translate instructing the GTiff driver to use that setting, whereas I'm not sure if rasterio
does the same by default. Writing 15 bits / pixel isn't a super fast code path in the GeoTIFF
driver. You could try adding -co NBITS=16
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200616/4ddd1063/attachment-0001.html>
