[gdal-dev] c# bindings - osr SpatialReference constructor
Tamas Szekeres szekerest at gmail.com
Tue Jun 16 11:12:37 PDT 2020
You should use null in the constructor if you don't want to specity a wkt
during the initialization, something like:
*SpatialReference srs = new
SpatialReference(null);srs.ImportFromEPSG(2927);*
Best regards,
Tamas
Paul Harwood <runette at gmail.com> ezt írta (időpont: 2020. jún. 16., K,
19:01):
> A common pattern for creating a SpatialReference is this :
> from osgeo import osr
> spatialRef = osr.SpatialReference()
> spatialRef.ImportFromEPSG(2927)         # from EPSG
> ( this example is from the Python Cookbook and is just used to illustrate
> the pattern)
> But - when I try to do the equivalent in c# using the bindings :
> SpatialReference CRS = new SpatialReference();
> CRS.ImportFromMICoordSys(coordsys);
> I get a message
> error CS1729: 'SpatialReference' does not contain a constructor that takes
> 0 arguments
> Am I missing something? Or is this is a gap in the bindings?
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200616/3927a85b/attachment.html>
