[gdal-dev] Source SRS is a compound CRS but lacks +geoidgrids
Even Rouault
even.rouault at spatialys.com
Tue Jun 16 13:34:23 PDT 2020
On mardi 16 juin 2020 20:22:57 CEST Comer, Alex wrote:
> Hello, I'm having trouble using gdalwarp to adjust the heights in a DEM from
> EGM96 heights to ellipsoidal heights.
> There is an example in the GDAL documentation
> (https://gdal.org/programs/gdalwarp.html#examples<https://urldefense.proofp
> oint.com/v2/url?u=https-3A__slack-2Dredir.net_link-3Furl-3Dhttps-253A-252F-2
> 52Fgdal.org-252Fprograms-252Fgdalwarp.html-2523examples-26v-3D3&d=DwMFAw&c=q
v9gmtOiXdJCj9gMlMKtaw&r=c5qG9R_C_Uk15wO7YCz0Kmxn1feCJcKpkdWjm6OrnHA&m=L
BJGDE
> isk_mehbQp1YF7U2vnpaqKAyB1WlXNejSAiHc&s=SPJdv5gp9MY8S77hKdINBORe-
qDXH6QvCJa4
> mrKxl9c&e=> , near the end of the page):
> * To transform a DEM from geoid elevations (using EGM96) to WGS84
> ellipsoidal heights:
> New in version 2.2.
> gdalwarp -overwrite in_dem.tif out_dem.tif -s_srs EPSG:4326+5773 -t_srs
> EPSG:4979
> When I run this command using GDAL 3.1.0 and PROJ 7.0.1, the output is
> unchanged from the input. My expectation is that the heights would be
> adjusted in the output file.
> If I set CPL_DEBUG=ON, I see the message:
> GDALWARP: Source SRS is a compound CRS but lacks +geoidgrids
> Using gdalsrsinfo to examine the SRS "EPSG:4326+5773" shows a WKT that
> notably does not refer to +geoidgrids in the PROJ string:
> $ gdalsrsinfo EPSG:4326+5773
> PROJ.4 : +proj=longlat +datum=WGS84 +vunits=m +no_defsOGC WKT2:2018 :
> COMPOUNDCRS["WGS 84 + EGM96 height",
> GEOGCRS["WGS 84",
> DATUM["World Geodetic System 1984",
> ELLIPSOID["WGS 84",6378137,298.257223563,
> LENGTHUNIT["metre",1]]],
> PRIMEM["Greenwich",0,
> ANGLEUNIT["degree",0.0174532925199433]],
> CS[ellipsoidal,2],
> AXIS["geodetic latitude (Lat)",north,
> ORDER[1],
> AXIS["geodetic longitude (Lon)",east,
> ORDER[2],
> USAGE[
> SCOPE["unknown"],
> AREA["World"],
> BBOX[-90,-180,90,180]],
> ID["EPSG",4326]],
> VERTCRS["EGM96 height",
> VDATUM["EGM96 geoid"],
> CS[vertical,1],
> AXIS["gravity-related height (H)",up,
> LENGTHUNIT["metre",1]],
> USAGE[
> SCOPE["unknown"],
> AREA["World"],
> ID["EPSG",5773]]]
> A colleague using GDAL v2.4.1 had a different result. Note the reference to
> +geoidgrids=egm95_15.gtx and the PROJ4_GRIDS extension:
> PROJ.4 : +proj=longlat +datum=WGS84 +geoidgrids=egm96_15.gtx +vunits=m
> +no_defsOGC WKT : COMPD_CS["WGS 84 + EGM96 geoid height",
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563,
> AUTHORITY["EPSG","7030"]],
> AUTHORITY["EPSG","6326"]],
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.0174532925199433,
> AUTHORITY["EPSG","9122"]],
> AUTHORITY["EPSG","4326"]],
> VERT_CS["EGM96 geoid height",
> VERT_DATUM["EGM96 geoid",2005,
> EXTENSION["PROJ4_GRIDS","egm96_15.gtx"],
> AUTHORITY["EPSG","5171"]],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> AXIS["Up",UP],
> AUTHORITY["EPSG","5773"]]]
> Indeed, with GDAL 3.1.0 & PROJ 7.0.1 I am able to achieve the desired result
> if I use a PROJ string rather than the EPSG:horiz+vertical code. For
> example something like:
> gdalwarp -s_srs "+proj=longlat +datum=WGS84 +no_defs
> +geoidgrids=egm96_15.gtx" -t_srs "+proj=longlat +datum=WGS84 +no_def"
> input.tif output.tif
Yes, since GDAL 3 / PROJ 6, this is the expected way to proceed, even if admitedly not ideal
and could benefit from enhancements, since EPSG:5773 is no longer automatically expanded
(for "good" reasons) to +geoidgrids=egm96_15.gtx , and gdalwarp in height adjustment
mode requires an explicit mention of geoidgrids.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200616/3bc6b01e/attachment-0001.html>
