[gdal-dev] Source SRS is a compound CRS but lacks +geoidgrids
Patrick Young
patrick.mckendree.young at gmail.com
Tue Jun 16 14:47:42 PDT 2020
Thanks Even, really helpful!
Patrick
On Tue, Jun 16, 2020 at 3:45 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> On mardi 16 juin 2020 15:17:54 CEST Patrick Young wrote:
> > Is this a special case for EPSG:5773, or is it a bad idea to express the
> > vertical datum via EPSG codes in general?
> This could go in a lengthy geodesy lesson, but bascially a CRS definition
> and its transformation to another one are two separate concepts. PROJ < 6
> tended to blend them together, by including the transformation to WGS84 in
> the CRS definition. For number of cases, this is accurate enough, but this
> systematic use of WGS84 pivot is more and more wrong in a number of
> situations, hence this is no longer used systematically in PROJ 6. PROJ < 6
> behaviour was a "early binding" (to WGS84), while PROJ 6 uses a "late
> binding" approach where it might use a WGS84 pivot, or another one, or a
> direct transformation when available
> Some details about that in:
> http://download.osgeo.org/proj/presentations/PROJ%20CRS%20revamp%20(FOSS4G%202019).pdf
> So by adding +geoidgrids=egm96_15.gtx you force the geoid to be referenced
> to WGS84. Which makes sense in this particular case, since indeed EGM96
> height has a transformation to WGS84, but not in the general case.
> The current approach used by gdalwarp to do those height correction is a
> bit of a "hack". A more generalized approach would use PROJ capabilities to
> compute the Z difference without GDAL to have to explicitly use the
> geoidgrid.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200616/36d5debe/attachment-0001.html>
