[gdal-dev] How to build py-gdal using the C++ compiler
Kurt Schwehr
schwehr at gmail.com
Wed Jun 17 06:57:20 PDT 2020
Here is the (very out of date) fink setup for gdal for comparison:
https://github.com/fink/fink-distributions/blob/master/10.9-libcxx/stable/main/finkinfo/libs/pythonmods/gdal-py.info#L43
https://github.com/fink/fink-distributions/blob/master/10.9-libcxx/stable/main/finkinfo/libs/pythonmods/gdal-py.patch
Sorry it's such an old version of GDAL. I haven't contributed to fink in a
while.
-kurt
On Wed, Jun 17, 2020 at 6:38 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> On mardi 16 juin 2020 20:41:28 CEST Ryan Schmidt wrote:
> > Hello, I'm a developer with MacPorts. We have this problem: py-gdal is
> > written in C++ but it gets compiled using the C compiler and CFLAGS and
> > linked using the C++ compiler and LDFLAGS. We would like it to be
> compiled
> > using the C++ compiler and CXXFLAGS. How can this be accomplished? We
> have
> > a need to supply the build with certain flags in CXXFLAGS but they are
> > currently being ignored, resulting in build failures like this:
> > https://trac.macports.org/ticket/57621
> > I know that distutils simply has the defect that it does not support C++
> > software at all, resulting in the above condition. This bug was never
> fixed
> > before distutils was retired.
> > https://bugs.python.org/issue1222585
> > I am trying to figure out whether distutils' replacement setuptools is
> still
> > suffering from the same problem and needs to be fixed or whether there is
> > something that needs to be changed in py-gdal and other similar projects
> to
> > make it work. Do you know?
> What is py-gdal exactly ? A build of the "official" GDAL SWIG Python
> bindings ?
> Python extension building is always a bit of black magick to me, but our
> continuous integration does include building them on the Mac. For example,
> https://github.com/OSGeo/gdal/runs/779871427 . I guess this must be
> through setuptools
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200617/5bbe1144/attachment.html>
