[gdal-dev] How to convert GDAL Vector dataset to memory stream
MRRAJESH
rajeshreddy82 at gmail.com
Sat Jun 20 22:10:54 PDT 2020
Hi Tamas,
Thanks for your suggestions. Will it work for MVT memory dataset?
We have an MVT memory dataset with us. How to convert this to memory stream.
*Example: *
var vsibuf = string.Format(@"/vsimem/mvt");
var newDs = Gdal.wrapper_GDALVectorTranslateDestName(vsibuf, ds1,
gdalOptions, null, null);
newDs.Dispose();
string filePath = string.Format("{0}\\{1}\\{2}\\{3}.mvt", vsibuf, 18, 66027,
96262);
We tried below ways:
*Way1:*
Dataset ds = Gdal.OpenEx(filePath, 0, null, open_options, null);
How to convert a dataset (ds) to memory stream?
*Way2:*
var bufPtr = Gdal.VSIFOpenL(filePath, "rb");
if (bufPtr != null)
Gdal.VSIFSeekL(bufPtr, 0, 2); // seek to end
var contentSize = Gdal.VSIFTellL(bufPtr1);
Gdal.VSIFSeekL(bufPtr1, 0, 0); // seek to beginning
var data = new byte[contentSize];
var content = VSIFReadL(1, contentSize, bufPtr); // This method is
not available in C#.
How to get content here?
Regards,
Rajesh
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
