[gdal-dev] Problems loading swedish climate data to PostGIS
Thiemo Kellner
thiemo at gelassene-pferde.biz
Tue Jun 23 13:35:15 PDT 2020
Hi Jeff
Thank you for sharing your steps. I tried to follow them and had an
insight though I am still stuck. I noticed that I was passing the gdb
file within the unzipped folder to ogr2ogr whereas you passed the
folder path. Switching to your pattern it looks as follows.
thiemo @ thiemos-toshi /mnt/schweden % ogrinfo --formats | grep -i postg
PostgreSQL -vector- (rw+): PostgreSQL/PostGIS
PGDUMP -vector- (w+v): PostgreSQL SQL dump
# PostGIS capabilities of ogrinfo proven
PG:"host='/var/run/postgresql' port='6543' dbname='sverige'
user='sverige'"
INFO: Open of `PG:host='/var/run/postgresql' port='6543'
dbname='sverige' user='sverige''
using driver `PostgreSQL' successful.
1: tiger.county (Multi Polygon)
2: tiger.state (Multi Polygon)
# Connection to PostGIS works
thiemo @ thiemos-toshi /mnt/schweden % ogrinfo SCID_v4.0.gdb
INFO: Open of `SCID_v4.0.gdb'
using driver `OpenFileGDB' successful.
1: HBVSv_intrans_HQloc100_rcp45_ensembleMean_diffPerc (Multi Polygon)
2: HBVSv_intrans_HQloc100_rcp85_ensembleMean_diffPerc (Multi Polygon)
# Proven to be able to read the gdb file(s)
HBVSv_intrans_HQloc100_rcp85_ensembleMean_diffPerc -summary
Layer name: HBVSv_intrans_HQloc100_rcp85_ensembleMean_diffPerc
Geometry: Multi Polygon
Feature Count: 1103
# Proven to be able to access a specific layer in the gdb
thiemo @ thiemos-toshi /mnt/schweden % ogr2ogr –f "PostgreSQL"
-overwrite –progress --config PG_USE_COPY YES
PG:"host='/var/run/postgresql' port='5432' dbname='sverige'
user='sverige'" SCID_v4.0.gdb
FAILURE:
Unable to open datasource `PostgreSQL' with the following drivers.
-> `PCIDSK'
# UNABLE TO USE ogr2ogr TO WRITE DATA TO MY PostGIS
thiemo @ thiemos-toshi /mnt/schweden :-( % ogr2ogr –f "ESRI Shapefile"
test.shp SCID_v4.0.gdb/gdb.shp SCID_v4.0.gdb
FAILURE:
Unable to open datasource `ESRI Shapefile' with the following drivers.
-> `PCIDSK'
# To me it seems that I am not able to use ogr2ogr eventhough I can
ogrinfo shape files
thiemo @ thiemos-toshi /mnt/schweden % ogrinfo --formats | grep -i esri
ESRI Shapefile -vector- (rw+v): ESRI Shapefile
ESRIJSON -vector- (rov): ESRIJSON
PGeo -vector- (ro): ESRI Personal GeoDatabase
OpenFileGDB -vector- (rov): ESRI FileGDB
I am pritty lost.
Kind regards
Thiemo
Quoting Jeff McKenna <jmckenna at gatewaygeomatics.com>:
> Hi Thiemo!
> I have downloaded your data, to hopefully show you how I would tackle this.
> First thing is to take this in very small steps, to confirm along
> the way, otherwise you jump to ogr2ogr without confirming that it is
> even possible on your system - in other words, live by *ogrinfo*,
> ogrinfo is your friend, and only move to ogr2ogr once you have
> ogrinfo happy, and then later use ogrinfo again for confirmation.
> Here are my notes, I've made comments with the # symbol, and I
> should also mention that I am testing on Windows, with MS4W, so
> sometimes the exact command may slightly change (such as a single
> quote instead of a double quote in a command, on Linux systems) :
> create database
> #must first create an empty db (named 'scid' here), and load the
> PostGIS extension
> createdb -U postgres -p 5436 -E UTF8 scid
> psql -U postgres -d scid -p 5436 -c "CREATE EXTENSION postgis;"
> psql -U postgres -d scid -p 5436 -c "CREATE EXTENSION postgis_topology;"
> ogrinfo
> #verify that your local GDAL/OGR is built with PostGIS and FileGDB support
> ogrinfo --formats
> MySQL -vector- (rw+): MySQL
> XPlane -vector- (rov): X-Plane/Flightgear aeronautical data
> DXF -vector- (rw+v): AutoCAD DXF
> #connect to your new database (see params for the PG driver at
> https://gdal.org/drivers/vector/pg.html )
> ogrinfo PG:"host=localhost user=postgres password=postgres port=5436
> dbname=scid"
> INFO: Open of `PG:host=localhost user=postgres password=postgres
> port=5436 dbname=scid'
> #we're in business, no errors, yet no spatial tables listed yet,
> because there is none
> #examine the file geodatabase
> #in my case, MS4W uses the 'OpenFileGDB' driver, but the 'FileGDB'
> driver is also possible
> #356 layers should be listed there, with their layer names. I'll
> use the last layer listed in the long list:
> 356: HBVSv_MLSM_rcp85_ensembleMax_abs (Multi Polygon)
> #so the layer name is 'HBVSv_MLSM_rcp85_ensembleMax_abs'
> #examine the single layer through OGR/GDAL
> ogrinfo SCID_v4.0.gdb HBVSv_MLSM_rcp85_ensembleMax_abs -summary
> - lists that there are 1103 features in that layer
> - EPSG (projection): https://epsg.io/3006
> ogr2ogr
> #now you are ready to use ogr2ogr to bring the FileGDB layer into
> your empty PG/PostGIS database
> ogr2ogr -f PostgreSQL PG:"host=localhost user=postgres
> password=postgres port=5436 dbname=scid" SCID_v4.0.gdb
> ogrinfo
> #use ogrinfo to confirm that the new spatial layer exists in your PG database
> dbname=scid"
> - should list your new layer 'hbvsv_mlsm_rcp85_ensemblemax_abs'
> #examine your new layer
> dbname=scid" hbvsv_mlsm_rcp85_ensemblemax_abs -summary
> Hope this helps. Welcome to the FOSS4G community!
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> co-founder of FOSS4G
> http://gatewaygeo.com/
> On 2020-06-23 4:27 a.m., Thiemo Kellner wrote:
>> Hi
>> I am new to spacial data processing. For a project of mine I try to
>> load swedish climate data in to my PostGIS installation
>> running/using an openSUSE Tumbleweed installation.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
S/MIME Public Key: https://oc.gelassene-pferde.biz/index.php/s/eJuAUFONag6ofnH
Signal (Safer than WhatsApp): +49 1578 7723737
Handys: +41 78 947 36 21 | +49 1578 772 37 37
Type: application/pkcs7-signature
Desc: S/MIME Signature
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200623/9dd9931b/attachment.bin>
