[gdal-dev] GFS with condition on the second last element
Raymond Nijssen
r.nijssen at terglobo.nl
Wed Jun 24 20:29:45 PDT 2020
Thanks Even,
Then at least I can stop searching.
For now I will move to iterparse in python, which is slow but very flexible.
Raymond
On 24-06-2020 18:11, Even Rouault wrote:
> On mercredi 24 juin 2020 17:14:50 CEST Raymond Nijssen wrote:
> > Hi list,
> > I'm trying to read a complex gml file that includes values that need to
> > be selected on an xml attribute. This is possible to do with a condition
> > in the gfs file, but the example only covers having the attribute on the
> > last element in the elementPath:
> https://gdal.org/drivers/vector/gml.html#using-conditions-on-xml-attributes
> > But mine is on the 2nd last element, like this:
> > <imaer:result>
> > <imaer:Result resultType="DEPOSITION" substance="NH3">
> > <imaer:value>0.01909</imaer:value>
> > </imaer:Result>
> > </imaer:result>
> > <imaer:result>
> > <imaer:Result resultType="DEPOSITION" substance="NOX">
> > <imaer:value>0.001341</imaer:value>
> > </imaer:Result>
> > </imaer:result>
> > So I'd like to do something like this in my gfs:
> > <PropertyDefn>
> > <Name>nh3</Name>
> > <ElementPath>result|Result|value</ElementPath>
> > <Condition>result|Result at substance='NH3'</Condition>
> > <Type>Real</Type>
> > </PropertyDefn>
> > to only catch the value where substance = NH3. I've been trying many
> > options but no success yet.
> > Is this even possible?
> No, this isn't possible. As documented, Condition capabilities are
> limited to filtering on an attribute of the same element whose value you
> want to retrieve.
> You would probably have more capabilities by using the GMLAS driver, and
> filtering on its output.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
