[gdal-dev] Issue with GDAL - JP2KAK driver
Even Rouault
even.rouault at spatialys.com
Sun Jun 28 03:20:05 PDT 2020
Boris,
> JP2KAK: DirectRasterIO() for 0,0,8192,8192 -> 512x512 (no intermediate)
This traces is probably a bit confusing, but it means that it reads from the overview you
specified.
> CPLSetConfigOption("CPL_VSIL_CURL_CHUNK_SIZE", "1000000");
This is probably the reason for the behaviour you observe. JPEG2000 files aren't necessarily
all optimized for efficient overview retrieval. You should check the "progression order" of
that file. If it is not RPCL or RLCP, the bits for overviews are scattered through the file, and so
with a large chunk size you'll read a lot of the file. If you reduced it, the total amount of bytes
read would be smaller, but you'd get a lot more GET requests.
But... with RPCL or RLCP progression order, reading a window at full resolution could become
less efficient than with PCRL
I don't think you can get with JPEG2000 something equivalent to TIFF + overviews, because
in TIFF + overviews you have redundancy of information (each resolution includes
information already found in lower resolution), whereas JPEG2000 is optimized to avoid that
redundancy, which also means that information is scattered through the file.
> The higher the overview, the bigger the request from S3, as if GDAL reads
> the best resolution and resamples the results.
Yes, that's "expected" given the above.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200628/85308ee4/attachment.html>
