[gdal-dev] Problems with reading data into SQLServer
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Mon Jun 29 04:45:07 PDT 2020
Hi all -
I'm trying to use ogr2ogr to read shape data into a SQL Server Spatial
database using ogr2ogr.
The problem is that I have a insert trigger (which is absolutely
necessary) on the receiving table.
The command is like this:
*ogr2ogr.exe --config MSSQLSPATIAL_USE_BCP false -append -skipfailures
-a_srs EPSG:25832 -nlt PROMOTE_TO_MULTI -nln gnss_data -lco
SCHEMA=transit -lco SPATIAL_INDEX=no -lco GEOMETRY_NAME=sp_geometry -lco
FID=mi_prinx -dialect SQLITE -sql "SELECT ID AS id, TYPENAVN AS
typenavn, KATEGORI AS kategori, REGISTRE AS registrering,
ST_GeometryType(geometry) AS kommentar, DATO AS oprettet, INITIALER AS
ini, 'Punkter.shp' AS filepath, geometry as sp_geometry from ""Punkter""
where IsEmpty(geometry) = 0 and IsValid(geometry) = 1" -f "MSSQLSpatial"
"MSSQL:server=localhost\SQLExpress;database=drc-spor;trusted_connection=yes;"
"Punkter.shp"***
Activates trigger, but is slow (even if I deactivate the trigger)
*ogr2ogr.exe --config MSSQLSPATIAL_USE_BCP true -append -skipfailures
"Punkter.shp"***
No error and data is correctly read and imported fast, but no trigger
activation.
Is there a qualifier/config option to get a trigger executed even if you
are using the bcp-copy method for importing data into SQLServer ?
Med venlig hilsen / Kind regards
Bo Victor Thomsen
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200629/c3ff6099/attachment.html>
