[gdal-dev] extra column id is present when converted to csv from topojson
Wuyyuru Ravi Teja Krishna ravitejakrishna.w at zohocorp.com
Tue Jun 30 03:23:58 PDT 2020
Hello,
I am using ogr2ogr with java bindings. When iam trying to convert a topojson file to a csv file an extra column named "id" is coming in converted csv file with null values. How can i convert from topojson to csv without getting such extra columns.
the command i am using for conversion is as below
java -cp :gdal.jar -Djava.library.path=libs/ ogr2ogr "-s_srs" "CRS:84" "-t_srs" "CRS:84" "-f" "CSV" filename.csv filename.topojson "-lco" "GEOMETRY=AS_WKT"
Thanks in advance.
Any clarification regarding this issue will be helpful to us.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200630/a4a254bf/attachment.html>
