[gdal-dev] Importing ESRI (EPSG?) 102008 in GDAL 3.x/PROJ 6
Daniel Evans
Daniel.Evans at jbarisk.com
Thu Mar 5 08:11:57 PST 2020
Hi Even,
> epsg.io should not be taken as a reference website (even if more up-to-date than spatialreference.org). The WKT you see there has been built by some piece of software, and is in no way the original ESRI > WKT (ESRI WKT has no AUTHORITY node)
Thanks for the note. I was mostly rather confused by whether it was considered an official EPSG code (if such a thing even exists), relegated to being a custom ESRI one with "ESRI" as a prefix, or something totally different.
> srs.SetFromUserInput("ESRI:102008")
That's the magic one-liner I was hoping for. Thanks!
Dr. Daniel Evans
Software Developer
-----Original Message-----
Sent: 05 March 2020 16:01
To: gdal-dev at lists.osgeo.org
Cc: Daniel Evans <Daniel.Evans at jbarisk.com>
Subject: Re: [gdal-dev] Importing ESRI (EPSG?) 102008 in GDAL 3.x/PROJ 6
Daniel,
> While upgrading some Python software from using GDAL 2.3 to GDAL 3,
> I've come across this snippet of code:
> srs = osr.SpatialReference()
> srs.ImportFromEPSG(102008)
> This used to work, but now fails with GDAL 3 / Proj 6 with "crs not found".
yep, we're more pedantic now, and don't mix EPSG and ESRI codes together.
> Projection code 102008 corresponds to "ESRI:102008" described here,
> which the WKT output describes as "EPSG 102008":
> https://epsg.io/102008
epsg.io should not be taken as a reference website (even if more up-to-date than spatialreference.org). The WKT you see there has been built by some piece of software, and is in no way the original ESRI WKT (ESRI WKT has no AUTHORITY
node)
> Is there an easy way to create an SRS from the code 102008 (perhaps
> with some prefix/suffix) in GDAL 3 / PROJ 6? The projection and its
> code are included in the PROJ source data
> (https://github.com/OSGeo/PROJ/blob/master/data/sql/esri.sql), but I
> can't figure out what combination of "ImportFrom..." function and
> projection code format to use.
> (There is a possibility that the GDAL 2.3 build we have has 102008
> added into the data files - the history of the custom fork of GDAL
> we're moving away from isn't well documented)
No, stock GDAL 2.4 will also output
$ gdalsrsinfo EPSG:102008
PROJ.4 : +proj=aea +lat_1=20 +lat_2=60 +lat_0=40 +lon_0=-96 +x_0=0 +y_0=0
+datum=NAD83 +units=m +no_defs
OGC WKT :
PROJCS["North_America_Albers_Equal_Area_Conic",
GEOGCS["GCS_North_American_1983",
DATUM["North_American_Datum_1983",
SPHEROID["GRS_1980",6378137.0,298.257222101]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Albers_Conic_Equal_Area"],
PARAMETER["False_Easting",0.0],
PARAMETER["False_Northing",0.0],
PARAMETER["longitude_of_center",-96.0],
PARAMETER["Standard_Parallel_1",20.0],
PARAMETER["Standard_Parallel_2",60.0],
PARAMETER["latitude_of_center",40.0],
UNIT["Meter",1.0],
AUTHORITY["Esri","102008"]]
This is an arguable convenience that is no longer offered.
Even
Spatialys - Geospatial professional services http://www.spatialys.com
T +44 (0) 1756 799919
www.jbarisk.com<http://www.jbarisk.com>
[Visit our website]<http://www.jbarisk.com> [http://www.jbagroup.co.uk/imgstore/JBA-Email-Sig-Icons-LINKEDIN.png] <> [Follow us on Twitter] <https://twitter.com/jbarisk>
Our postal address and registered office is JBA Risk Management Limited, 1 Broughton Park, Old Lane North, Broughton, Skipton, North Yorkshire BD23 3FD.
Find out more about us here: www.jbarisk.com<http://www.jbarisk.com/> and follow us on Twitter @JBARisk<http://twitter.com/JBARisk> and LinkedIn<https://www.linkedin.com/company/2370847?trk=tyah&trkInfo=clickedVertical%3Acompany%2CclickedEntityId%3A2370847%2Cidx%3A2-1-2%2CtarId%3A1447414259786%2Ctas%3AJBA%20RISK%20MANAGEMENT>
The JBA Group supports the JBA Trust.
All JBA Risk Management's email messages contain confidential information and are intended only for the individual(s) named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system.
JBA Risk Management Limited is registered in England, company number 07732946, 1 Broughton Park, Old Lane North, Broughton, Skipton, North Yorkshire, BD23 3FD, Telephone: +441756799919
