[gdal-dev] Convert TIF to BIL
Bret Johnson
bret.johnson at utcg.com
Mon Mar 9 07:42:40 PDT 2020
GDALINFO Output:
Driver: EHdr/ESRI .hdr Labelled
Files: d:\470-600N_0900-0905W.bil
d:\X470-600N_0900-0905W.bil.aux.xml
d:\X470-600N_0900-0905W.hdr
d:\X470-600N_0900-0905W.prj
Size is 2784, 89882
Origin = (-10074427.220539299771190,7863030.092672790400684)
Pixel Size = (20.000000000000000,-20.000000000000000)
Metadata:
AREA_OR_POINT=Area
Corner Coordinates:
Upper Left (-10074427.221, 7863030.093)
Lower Left (-10074427.221, 6065390.093)
Upper Right (-10018747.221, 7863030.093)
Lower Right (-10018747.221, 6065390.093)
Center (-10046587.221, 6964210.093)
Band 1 Block=2784x1 Type=Int16, ColorInterp=Undefined
Min=0.000 Max=666.000
Minimum=0.000, Maximum=666.000, Mean=281.661, StdDev=147.479
NoData Value=-32767
Metadata:
STATISTICS_APPROXIMATE=YES
STATISTICS_MAXIMUM=666
STATISTICS_MEAN=281.66132304577
STATISTICS_MINIMUM=0
STATISTICS_STDDEV=147.47884400779
STATISTICS_VALID_PERCENT=93.76
As far as I can tell, nothing unusual there. BTW, I’ve tried with both EHDR and ENVI and it makes no difference.
Sent: Friday, March 6, 2020 9:42 PM
To: Bret Johnson <bret.johnson at utcg.com>
Cc: Even Rouault <even.rouault at spatialys.com>; gdal-dev <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] Convert TIF to BIL
Bret,
What does gdalinfo report on the file?
Markus
Bret Johnson <bret.johnson at utcg.com<mailto:bret.johnson at utcg.com>> schrieb am Fr., 6. März 2020, 19:19:
Even:
Thanks. That worked to create a World file, so I made it past the error message. It's still not importing correctly and the error message is so generic that it's useless (basically just says it doesn't like the data). I'll do some more playing.
-----Original Message-----
From: Even Rouault <even.rouault at spatialys.com<mailto:even.rouault at spatialys.com>>
Sent: Friday, March 6, 2020 1:15 PM
To: gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Cc: Bret Johnson <bret.johnson at utcg.com<mailto:bret.johnson at utcg.com>>
Bret,
> I have some GeoTIFF (.TIF) files that a program I'm using won't
> accept. It will accept .BIL files and I'm using GDAL to try and do the conversion.
> When I do, GDAL_TRANSLATE says it worked and it generates a few files
> (including a .BIL), but it doesn't create the .BLW file where all of
> the "real" data should be. Is there some special GDAL_TRANSLATE
> option or use or some special format GeoTIFF data needs to be in for
> it to work properly and generate a .BLW file?
I don't know which output driver you use (EHdr, ENVI etc.), but they aren't likely to produce a .blw worldfile as they will generate a text header file specific to the format.
To generate a .blw file you can do:
gdal_translate your_input.tif tmp.tif -co TFW=YES
This will generate a tmp.tfw file. Just rename it to .blw and with the basename of your BIL output file.
Even
Spatialys - Geospatial professional services http://www.spatialys.com
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200309/c0bc1243/attachment.html>
