[gdal-dev] /vsicurl/ and 3XX response code
aborruso
aborruso at gmail.com
Wed Mar 11 09:53:55 PDT 2020
Hi Even ,
Even Rouault-2 wrote
> No, this is an implementation detail. You'd have to use the curl or other
> HTTP
> API for that.
today a lot of datasets, especially structured text data, are hosted in
portals that reply with "HTTP/1.1 301 Moved Permanently".
A classic example are the many and preciuous CSV and JSON files that you
have in github gist.
It would be great to have as feature the option to follow the link (as in
curl via "-L" option), both using the gdal/ogr /vsicurl/ via command line
and via the definition of a VRT – GDAL Virtual Format XML file.
Is this the right place where I can create a feature request?
As usual thank you very much
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
