[gdal-dev] Infinite loop Netcdf/HDF5 -geoloc when warping (version 2.4.4)
Even Rouault even.rouault at spatialys.com
Thu Mar 12 11:16:39 PDT 2020
Jeff,
> I have also tested one of your files on Windows here, with MS4W 4.0.3
> (GDAL 2.4.4, NetCDF 4.7.3, HDF5 1.10.5), and it also gives me errors:
They look unrelated to Menno's error.
> Warning 1: NetCDF driver detected file type=5, but libnetcdf detected type=3
That one is likely related to MS4W nmake.opt lacking NETCDF_HAS_NC4 = yes
> ERROR 5: OSRCalcInvFlattening(): Wrong input values
Yep, that one is related to the oddity of the semi_minor_radius vs
semi_major_radius I mentionned before.
> MS4W does include C Sharp GDAL bindings but I did not test them with
> your data.
That's completely unrelated.
Even
http://www.spatialys.com
