[gdal-dev] Infinite loop Netcdf/HDF5 -geoloc when warping (version 2.4.4)
Menno van Scheers - HUSS menno at huss.nl
Fri Mar 13 01:04:25 PDT 2020
Hi Even, Jeff
I checked both the 3.0.x and 2.4.4 release from  http://www.gisinternals.com/
They both report :
    GDAL_HAS_HDF4=YES
    GDAL_HAS_HDF5=YES
    NETCDF_CONVENTIONS=CF-1.5
    NETCDF_HAS_NC2=YES
    NETCDF_VERSION=4.3.2 of Sep  3 2017 18:13:37
Are the gdal nuget package based on these builds ?
And am I safe to assume the issue is due to this old NETCDF version
Best Regards,
Menno Van Scheers
-----Oorspronkelijk bericht-----
Van: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Namens Jeff McKenna
Verzonden: donderdag 12 maart 2020 19:30
Aan: gdal-dev at lists.osgeo.org
Onderwerp: Re: [gdal-dev] Infinite loop Netcdf/HDF5 -geoloc when warping (version 2.4.4)
On 2020-03-12 3:16 p.m., Even Rouault wrote:
> Jeff,
>> I have also tested one of your files on Windows here, with MS4W 4.0.3
>> (GDAL 2.4.4, NetCDF 4.7.3, HDF5 1.10.5), and it also gives me errors:
> They look unrelated to Menno's error.
>> Warning 1: NetCDF driver detected file type=5, but libnetcdf detected
>> type=3
> That one is likely related to MS4W nmake.opt lacking NETCDF_HAS_NC4 =
> yes
Thanks Even, confirmed, will fix this for next release.
-jeff
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
