[gdal-dev] Need some help understanding why this raster is so big
CainĂ£ K. Campos
rupestre.campos at gmail.com
Fri Mar 13 05:33:45 PDT 2020
Hello Brian,
Try to add the switch -co "COMPRESS=LZW" to the command line to generate
a compressed result with lossless compression.
On Fri, Mar 13, 2020 at 9:07 AM Brian <mulcahy.brianp at gmail.com> wrote:
> So compressed this raster is fairly small about 120mb but running
> gdal_warp produces a raster that is about 416 gb, is this something this
> list can help with? If so I can upload the file somewhere and let you
> guys/gals take a look at it.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200313/e7afe070/attachment.html>
