[gdal-dev] ogr2ogr - double free or corruption (out)
Danziger, Robert C. Robert.Danziger at eui.eu
Mon Mar 16 05:54:20 PDT 2020
Ubuntu 18.04 (LTR).
since (apt) upgrade 3-4 days ago every invocation of 'ogr2org' (GDAL 3.0.2) generates the following messages:
"Double free or corruption (out)"
"Aborted (core dumped)"
Every invocation produces this, regardless whether an attempt to convert posgresql => geojson or a simple 'ogr2ogr --version' command.
=> However the command appears to execute correctly (i.e. the postgresql => geojson does get executed as desired but the messages are thrown anyway.)
Any attempt to apt upgrade shows gdal-bin, gdal-data, libgdal26, python3-gdal as well as qgis and grass packages 'kept back'.
(Note: I have attempted to "force" an upgrade of these packages but this has not worked and resulted in a situation of having to completely restore the system -- successfully-- from a very recent cold backup.)
PostgreSQL Server version: 11.7
Best regards
The information transmitted is intended only for the person or entity to which it is addressed and may contain confidential and/or privileged material. Any review, retransmission, dissemination, distribution, forwarding, or other use of, or taking of any action in reliance upon, this information by persons or entities other than the intended recipient is prohibited without the express permission of the sender. If you received this communication in error, please contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200316/183b0074/attachment.html>
