[gdal-dev] Invalid dataset dimensions : -2147483648 x -2147483648 Error While using gdalinfo
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Tue Mar 17 02:18:38 PDT 2020
Works for me with GDAL GDAL 3.0.4
gdalinfo
https://services.arcgisonline.com/arcgis/rest/services/Polar/Arctic_Ocean_Base/MapServer/WMTS/1.0.0/WMTSCapabilities.xml
Driver: WMTS/OGC Web Map Tile Service
Files: none associated
Size is 1073741823, 1073741823
Coordinate System is:
PROJCRS["WGS 84 / EPSG Alaska Polar Stereographic",
-Jukka Rahkonen-
san619 wrote
> Im getting a error message : "Invalid dataset dimensions : -2147483648 x
> -2147483648" while using gdalinfo for a wmts url.What is the reason for
> the
> error.How to resolve this.The WMTS Url used is :
> "https://services.arcgisonline.com/arcgis/rest/services/Polar/Arctic_Ocean_Base/MapServer/WMTS/1.0.0/WMTSCapabilities.xml".
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
