[gdal-dev] Invalid dataset dimensions : -2147483648 x -2147483648 Error While using gdalinfo
Even Rouault even.rouault at spatialys.com
Tue Mar 17 08:30:41 PDT 2020
On mardi 17 mars 2020 05:57:54 CET san619 wrote:
> But in some cases im not getting the extent of the layer.What could be the
> reason.I tried in both versions 2.3.2 and 3.0.4.But still same,extent is
> empty in the output.
> WMS layer :
> http://services.ga.gov.au/gis/services/NEXIS_Agricultural_Exposure/MapServer
> /WMSServer?request=GetCapabilities&service=WMS
> JSON output:
This service exposes 2 WMS layers, which are reported as 2 GDAL subdatasets by
the top-level GDAL dataset. So you need to open then the dataset names pointed
by SUBDATASET_1_NAME or SUBDATASET_2_NAME to get datasets with raster content.
http://www.spatialys.com
