[gdal-dev] Loading GeoJSON to ES 7
Francesco Bartoli xbartolone at gmail.com
Tue Mar 17 12:52:07 PDT 2020
Hi All,
I'm trying to investigate this issue https://github.com/geopython/pygeoapi/issues/379 in the pygeoapi project. I'm using an instance of ES7 and if I understand well the command below:
docker run --rm --network=host -u $(id -u ${USER}):$(id -g ${USER}) \
-v $(pwd):/data \
-e OGR_GEOJSON_MAX_OBJ_SIZE=500MB \
osgeo/gdal:alpine-small-latest \
ogr2ogr -lco INDEX_NAME=pygeoapi ES:localhost:9200 /data/tests/data/ne_110m_populated_places_simple.geojson
should create a Feature object in the index or am I wrong? Actually I don't have a geojson object:
    "took": 3,
    "timed_out": false,
    "_shards": {
        "total": 1,
        "successful": 1,
        "skipped": 0,
        "failed": 0
    "hits": {
        "total": {
            "value": 243,
            "relation": "eq"
        "max_score": 1.0,
        "hits": [
                "_index": "pygeoapi",
                "_type": "_doc",
                "_id": "EfwD6nAB8v4-ZVfFzLGS",
                "_score": 1.0,
                "_source": {
                    "geonameid": 6691831.0,
                    "geometry": {
                        "type": "POINT",
                        "coordinates": [
                            12.453386545,
                            41.90328218
                    "scalerank": 8,
                    "natscale": 10,
                    "labelrank": 3,
                    "featurecla": "Admin-0 capital",
                    "name": "Vatican City",
                    "namepar": null,
                    "namealt": null,
                    "diffascii": 0,
                    "nameascii": "Vatican City",
                    "adm0cap": 1.0,
                    "capalt": null,
                    "capin": null,
                    "worldcity": 1.0,
                    "megacity": 0,
                    "sov0name": "Vatican (Holy Sea)",
                    "sov_a3": "VAT",
                    "adm0name": "Vatican (Holy See)",
                    "adm0_a3": "VAT",
                    "adm1name": "Lazio",
                    "iso_a2": "VA",
                    "note": null,
                    "latitude": 41.900012226400001,
                    "longitude": 12.4478083889,
                    "changed": 4.0,
                    "namediff": 0,
                    "diffnote": "Changed scale rank.",
                    "pop_max": 832,
                    "pop_min": 832,
                    "pop_other": 562430,
                    "rank_max": 2,
                    "rank_min": 2,
                    "meganame": null,
                    "ls_name": "Vatican City",
                    "ls_match": 1,
                    "checkme": 0,
                    "min_zoom": 7.0
Thanks,
Francesco
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200317/09a216b3/attachment-0001.html>
