[gdal-dev] Loading GeoJSON to ES 7
Francesco Bartoli xbartolone at gmail.com
Wed Mar 18 01:05:39 PDT 2020
Thanks Even, I was misleading the behavior. However, is there a way to ingest and set the value of a unique identifier, for instance geonameid, in the key _idĀ of each item of the index?
Francesco
Il 17 mar 2020, 22:13 +0100, Even Rouault <even.rouault at spatialys.com>, ha scritto:
> Francesco,
> The behaviour in ES7 has been changed. Now only flat structure is supported.
> This was discussed in https://github.com/OSGeo/gdal/issues/1246 and I've just
> made the doc of the driver clearer:
> - **MAPPING_NAME=**\ =name. (Elasticsearch < 7) Name of the mapping type
> within the index.
> By default, the mapping name is "FeatureCollection" and the documents
> will be written as GeoJSON Feature objects. If another mapping name
> is chosen, a more "flat" structure will be used. This option is
> ignored when converting to Elasticsearch >=7 (see `Removal of mapping types
> <https://www.elastic.co/guide/en/elasticsearch/reference/current/removal-of-types.html>`__).
> With ElasticSearch 7 or later, a "flat" structure is always used.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200318/9fe5f9ff/attachment.html>
