[gdal-dev] ogr2ogr - double free or corruption (out)
Danziger, Robert C. Robert.Danziger at eui.eu
Wed Mar 18 08:05:28 PDT 2020
Thank you. At this point I have decided to do nothing and will wait to see if a future update will resolve the problem. As I mentioned, despite the error, the calls to ‚ogr2ogr‘ do produce the results I need (GeoJSON outputs from Postgresql) and otherwise seem to have no side effects (except a dump file). Once I move to the next QGIS LTR (I am at 3.4) compatible with the Lizmap plugin I use, we‘ll see what happens.
Best regards.
Téléchargez Outlook pour iOS<https://aka.ms/o0ukef>
De : gdal-dev <gdal-dev-bounces at lists.osgeo.org> de la part de Andre Joost <andre+joost at nurfuerspam.de>
Envoyé : Monday, March 16, 2020 7:19:32 PM
À : gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Objet : Re: [gdal-dev] ogr2ogr - double free or corruption (out)
Am 16.03.20 um 13:54 schrieb Danziger, Robert C.:
> Ubuntu 18.04 (LTR). since (apt) upgrade 3-4 days ago every invocation
> of 'ogr2org' (GDAL 3.0.2) generates the following messages:
> =============================== "Double free or corruption (out)"
> "Aborted (core dumped)"
I assume you are using GDAL from the ubuntugis PPA.
There, GDAL has been upgraded to 3.0.4 on 2020-03-11.
Try to update. If the error persists, you may downgrade GDAL to the
version 2.2.3 from the main ubuntu repo.
For QGIS, you might have to wait for the next point release to get it
working with GDAL 3.0.4.
HTH,
Andre Joost
gdal-dev mailing list
https://eur03.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fgdal-dev&data=02%7C01%7Crobert.danziger%40eui.eu%7Ce5f867496b45492b5c6d08d7c9dbe84d%7Cd3f434ee643c409f94aa6db2f23545ce%7C0%7C1%7C637199818640478213&sdata=88uEN%2Fj6uIn2WxO%2BxRP2qN4lUkdgzoLvgnvmmyrvCHI%3D&reserved=0
The information transmitted is intended only for the person or entity to which it is addressed and may contain confidential and/or privileged material. Any review, retransmission, dissemination, distribution, forwarding, or other use of, or taking of any action in reliance upon, this information by persons or entities other than the intended recipient is prohibited without the express permission of the sender. If you received this communication in error, please contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200318/d9e3ba16/attachment.html>
