[gdal-dev] Compiling gdal 2.4.4: "fatal error: mysql.h: No such file or directory"
aborruso aborruso at gmail.com
Thu Mar 19 07:51:26 PDT 2020
I'm building gdal 2.4.4 on CentOS Linux release 7.7.1908.
When I run "./configure --with-mysql=/usr/bin/mysql" I have no error.
Than when I run make I have
"make[3]: Entering directory
`/var/regsic/apps/gdal-2.4.4/ogr/ogrsf_frmts/mysql'
/bin/sh /var/regsic/apps/gdal-2.4.4/libtool --mode=compile --silent
--tag=CXX g++ -std=c++11 -I/var/regsic/apps/gdal-2.4.4/port
-I/var/regsic/apps/gdal-2.4.4/gcore -I/var/regsic/apps/gdal-2.4.4/alg
-I/var/regsic/apps/gdal-2.4.4/ogr
-I/var/regsic/apps/gdal-2.4.4/ogr/ogrsf_frmts
-I/var/regsic/apps/gdal-2.4.4/gnm -I/var/regsic/apps/gdal-2.4.4/apps
-DHAVE_AVX_AT_COMPILE_TIME -DHAVE_SSSE3_AT_COMPILE_TIME
-DHAVE_SSE_AT_COMPILE_TIME -g -O2  -Wall -Wextra -Winit-self
-Wunused-parameter -Wformat -Werror=format-security -Wno-format-nonliteral
-Wlogical-op -Wshadow -Werror=vla -Wmissing-declarations -Wnon-virtual-dtor
-Woverloaded-virtual -fno-operator-names -Wzero-as-null-pointer-constant
-I.. -I../..   -DGNM_ENABLED -I/var/regsic/apps/gdal-2.4.4/port
-DGDAL_COMPILATION -c -o ../o/ogrmysqldriver.lo ogrmysqldriver.cpp
In file included from ogrmysqldriver.cpp:29:0:
ogr_mysql.h:47:19: fatal error: mysql.h: No such file or directory"
"mysql.h" is in "/usr/include/mysql/mysql.h" and I have installed
mariadb-devel.
How to solve it?
Thank you
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
