[gdal-dev] gdalbuildvrt -separate from list of files with two bands
Scott Staniewicz
scott.stanie at gmail.com
Thu Mar 19 09:23:05 PDT 2020
Hi, I'd like to combine a large list of raster files (each of which has two
bands) into one .vrt, where each band of the VRT would have the 2nd band
from each file. I thought that the "-b 2" option , but doing
gdalbuildvrt -b 2 -separate outvrt.vrt *two2band_inputs.tif
just gives the warning that "... _____ has 2 bands. Only the first one will
be taken into account in the -separate case". I see that the code seems to
be not using the -b band option here, and just taking band one:
https://github.com/OSGeo/gdal/blob/master/gdal/apps/gdalbuildvrt_lib.cpp#L598-L603
Is there any way to do what I'm attempting? Is the -b option used for some
other reason in gdalbuildvrt?
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200319/5e7844af/attachment.html>
