[gdal-dev] Adding datasets to VRT at runtime
Even Rouault
even.rouault at spatialys.com
Sat Mar 21 02:46:54 PDT 2020
On vendredi 20 mars 2020 17:18:33 CET Mike wrote:
> Currently I have a workflow which uses GDALBuildVRT (in C++) to create a
> dataset with multiple geotiffs. I'm trying now to figure out if after this
> VRT dataset was created, is there a way to add an additional dataset
> without having to call GDALBuildVRT again?
> The main use case for this is I'm that loading geotiffs based on a paging
> system, and I'd like to be able to efficiently handle adding these new
> datasets. Any suggestions for where to look or maybe a different method is
> appreciated too.
Mie,
https://gdal.org/drivers/raster/vrt.html#creation-of-vrt-datasets gives an
example on how to add a new source with
oBand->SetMetadataItem( "source_0", szFilterSourceXML, "vrt_sources" );
You'd need to adapt the XML to use a SimpleSource or ComplexSource.
Otherwise a VRT is just a XML file, so you can also use your favorite XML
editing library
(or GDAL's minixml : https://gdal.org/doxygen/cpl__minixml_8h.html ) to edit
it as you wish.
Even
http://www.spatialys.com
