[gdal-dev] Building on windows
Rodrigo Avancini avancinirodrigo at gmail.com
Wed Mar 25 04:40:13 PDT 2020
I build gdal on windows without problem.
I am using nmake.opt to configure the build options:
https://trac.osgeo.org/gdal/wiki/GeneratingVisualStudioProject
After that:
copy nmake.opt nmake.local /Y
nmake -f makefile.vc MSVC_VER=1910 DLLBUILD=1 WIN64=1 VERSION=301
Best,
* Rodrigo Avancini *
Em ter., 24 de mar. de 2020 às 16:55, Jeff McKenna <
jmckenna at gatewaygeomatics.com> escreveu:
> Regarding your original error, googling it returns this discussion which
> has a GDAL connection, and a solution:
> https://stackoverflow.com/questions/60824242/suddenly-getting-builtin-ia32-sqrtsd-round-is-undefined-with-nvcc-gcc
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> https://gatewaygeomatics.com/
> On 2020-03-24 7:50 a.m., Darrel Maddy wrote:
> > Not having much luck here.  Anyone got any further suggestions?
> > I turned to windows because of a problem with my linux build  - this is
> > throwing up errors such as
> > /usr/lib/gcc/x86_64-linux-gnu/7/include/avx512fintrin.h(1761): error:
> > identifier "__builtin_ia32_sqrtsd_round" is undefined
> > /usr/lib/gcc/x86_64-linux-gnu/7/include/avx512fintrin.h(1770): error:
> > identifier "__builtin_ia32_sqrtss_round" is undefined
> > eclipse indicates these errors are being thrown during access to gdal.h
> > .  This program compiled and ran without error until last week. I have
> > not done anything to the gdal library or updated anything that I am
> > aware of. I will move back to linux if I can resolve this issue so any
> > suggestions for this would also be welcome.
> > If I cannot resolve these then I will move away from gdal as a general
> > library and write some generic data access tools.
> > Thanks
> > Darrel
> > *From:* Darrel Maddy
> > *Sent:* 17 March 2020 15:10
> > *To:* Jerome Siot <jerome.siot at mytimezero.com>;
> > 'gdal-dev at lists.osgeo.org' <gdal-dev at lists.osgeo.org>
> > *Subject:* RE: Building on windows
> > Dear Jérome
> > Many thanks for trying to help. Alas it is giving the same errors in the
> > Developer Command Prompt window.
> > Darrel
> > *From:*Jerome Siot <jerome.siot at mytimezero.com>
> > *Sent:* 17 March 2020 15:05
> > *To:* Darrel Maddy <darrel.maddy at newcastle.ac.uk>;
> > Hello,
> >   * Be sure to launch a terminal by executing :
> > C:\Program Files (x86)\Microsoft Visual
> > Studio\2019\Enterprise\Common7\Tools\LaunchDevCmd.bat
> >   * Then , give the VS version in nmake command :
> > nmake /f makefile.vc MSVC_VER=1900
> > Hope this helps, Jérome
> > *De :*gdal-dev <gdal-dev-bounces at lists.osgeo.org
> > <mailto:gdal-dev-bounces at lists.osgeo.org>> *De la part de* Darrel Maddy
> > *Envoyé :* Sunday, March 15, 2020 1:08 PM
> > *À :* 'gdal-dev at lists.osgeo.org' <gdal-dev at lists.osgeo.org
> > <mailto:gdal-dev at lists.osgeo.org>>
> > *Objet :* [gdal-dev] Building on windows
> > I have recently switched back to windows for a specific project that
> > uses the gdal library.  I am getting the following error on compilation
> > of the VS project
> > NMAKE : fatal error U1077: '"C:\Program Files (x86)\Microsoft Visual
> Studio\2019\Enterprise\VC\Tools\MSVC\14.22.27905\bin\HostX86\x64\cl.EXE"' :
> > return code '0x2'
> > The cl.exe file is present in the directory (there are a number of
> > similar messages that follow)  and I am unsure how to proceed. Any
> > suggestions?
> > Thanks
> > Darrel
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200325/19519ced/attachment.html>
