[gdal-dev] Issue with writen colortables
Even Rouault
even.rouault at spatialys.com
Thu Mar 26 13:46:50 PDT 2020
On jeudi 26 mars 2020 19:58:52 CET Joaquim Manuel Freire Luís wrote:
> images created with GMT but via GDAL.
> The .tif file looks right but if look at the .png (it needs lots of zoom) we
> can see that the top left pixel is missing. That happens, I think, because
> the transparency column has a first value of 0 whilst all the others are
> 1's. I checked this both with
You should probably not set the nodata value to 0. This will cause the alpha
component for entry 0 of the color table to be set to 0 when writing PNG
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200326/842455fc/attachment.html>
