[gdal-dev] Dealing with "default" TOWGS84 values
Greg Troxel
gdt at lexort.com
Tue Mar 31 09:05:35 PDT 2020
Even Rouault <even.rouault at spatialys.com> writes:
> I wanted to get opinions on a topic related to TOWGS84 7-parameter transforms. In the GDAL
> 1.x/2.x & PROJ 4.x/5.x era, having TOWGS84 values attached to CRS definitions was critical to
> get correct datum transformation.
> In GDAL 3, when such file is read, a BoundCRS object is returned, that is a CRS that has a base
> CRS (potentially with a EPSG code attached. e.g EPSG:27700) + the definition of its
> transformation to WGS84 (which corresponds to the transformation with larger area of use).
> Software like QGIS will then use this BoundCRS (since that's what GDAL returns for the
> dataset CRS) when reprojecting to a target CRS, which will cause the TOWGS84 parameters
> from the file to be used (PROJ >= 6 will honour the TOWGS84 parameters of a BoundCRS
> when transforming from/into it), rather than potentially more accurate transformations
> (typically grid based transformations) from the base CRS to the target CRS.
It seems the crucial point is whether one intends
to refer to a particular CRS, by just the codepoint, and therefore use
the most precise transform, following modern best practices, or
to refer sort of to a particular CRS, but with an inline definition of
it (the towgs84 params) to be used instead of the modern normal way
That second method is not even what I think was ever really intended by
most, but an artifact of how it was intended to be.
So I would be inclined to ignore the towgs84 parameters when reading a
CRS, if the codepoint is in the current database, unless an option has
been given stating they should be used.
I can see what you are saying about insisting that the towgs84 values
are the standard ones in order to ignore them, but it also seems like a
file with a crs codepoint and other towgs84 values is broken. I would
think it's better to allow it to be edited to change the CRS reference
to note that it's custom, since such a file isn't really using the
stated CRS.
Matching and skipping also feels fragile, rather than not using and
having people that want to use them have to be explicit.
