[gdal-dev] GDAL 3.1.0 RC2 available
Even Rouault
even.rouault at spatialys.com
Sun May 3 13:05:57 PDT 2020
> It's indeed not possible to make everybody happy, so the question is who
> you do mind the least to make unhappy.
> If nothing changes packagers like me will be unhappy because they need
> to reintroduce the virtual dependency for the unstable C++ ABI.
> C-only users will be unhappy about having to rebuild their code when the
> only C++ ABI breaks.
> And you will be unhappy if you have to split the library.
OK, so here's what I intend to change for RC3:
https://github.com/OSGeo/gdal/pull/2466/files
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200503/a59decb6/attachment-0001.html>
