[gdal-dev] S-57 driver Generic attribute DSNM
    loïc
    loic at justmagic.com
    Sun May  3 15:27:25 PDT 2020
Thank you all for your explanations.
I'm sad that this is a mistake in the doc :-) because as you pointed out S57 spec has no GUID definition. With the combination of the LNAM + DSNM, it allowed to have one that would be convenient in a PostGIS database that contains many S-57 charts.
On my fork of GDAL I add this attribute DSNM (as defined in the previous documentation),  and since the DSNM field is mandatory in the S57 spec I did not detect any problem.  (Tested with several S57 source US, UK, ES, HR, ... )
In case it would be helpful, I could make a PR.
-- loïc
> On 3 May 2020, at 12:49, Even Rouault <even.rouault at spatialys.com> wrote:
> On dimanche 3 mai 2020 09:54:22 CEST kusala nine wrote:
> > DSNM is dataset name. I'ts defined in the DSID which only occurs in the
> > first field/subfield group in the dataset - not sure what the driver does
> > in respect of it.
> Right. The driver doc was incorrect. I've just fixed it per
> https://github.com/OSGeo/gdal/commit/c0722aed716e01fa3ab0ccc20fb911369baa3721
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
