[gdal-dev] GDAL 3.1.0 RC2 available
Even Rouault even.rouault at spatialys.com
Sun May 3 17:14:35 PDT 2020
> Not 100% sure I followed, but:  If you change the shlib major
number,
> you have changed the ABI, even if the symbols are the same.
Yes, but the reasoning is actually the reverse: the (C++) ABI has
changed, so given libgdal contains both a C and C++ API, we
have to bump th shlib major number.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200504/0d4838fe/attachment.html>
