[gdal-dev] GDAL 3.1.0 RC2 available
Even Rouault
even.rouault at spatialys.com
Sun May 3 17:27:17 PDT 2020
> What I menat is that in the text of NEWS, you should not say that
the C
> ABI is unchanged. A "ABI has not changed" statement implies that
one
> can swap in the new binaries without rebuilding any depending
packages.
That would be true: you could replace the .so of GDAL 3.0 by the one
of 3.1 if the library/application that link to GDAL only use the C ABI.
But given that the .so name will change, you'll probably have to
recompile it anyway, unless you (ab)use symlinks tricks.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200504/c7e0c8ed/attachment.html>
