[gdal-dev] OGR GeoJSON transormation woes
Even Rouault even.rouault at spatialys.com
Thu May 7 03:47:51 PDT 2020
On jeudi 7 mai 2020 03:28:15 CEST jratike80 wrote:
> Hi,
> I fear that such a change in GeoJSON would not really correct anything but
> rather move the confusion into another place.
Yeah, especially since GeoJSON rather claims using OGC:1.3:CRS84 which is long, lat. But for
interoperability with EPSG, the OGR GeoJSON driver reports EPSG:4326, with
OAMS_TRADITIONAL_GIS_ORDER, and thus longitude, latitude coordinate order, as it has
done forever.
When you want to reproject a geometry coming from a OGR driver, you can just use the SRS
object of the layer or the geometry as the source CRS for the CoordinateTransformation
object that will have the axis mapping consistent with the order of the geometry
coordinates. No need to tweek axis mapping for the source.
For the target CRS, it is up to you to decide if you want to be authority compliant or in the
GIS-friendly camp :-)
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200507/610be8fc/attachment.html>
