[gdal-dev] gdal_viewshed
Howard Butler
howard at hobu.co
Thu May 7 09:41:14 PDT 2020
> On May 7, 2020, at 11:05 AM, Eli Adam <eadam at co.lincoln.or.us> wrote:
> The image with two dots makes me think that there can be multiple
> observer inputs. Is that the case? Is the syntax for that just to
> keep adding more -ox, -oy, (and oz)? For instance, gdal_viewshed -md
> 500 -ox -10147017 -oy 5108065 -ox -10147117 -oy 5108165+100 source.tif
> destination.tif
The picture is a poor example. You can't do multiple obvservers, but you can run a bunch of masks together and then merge to get a multipoint viewshed. I indeed made two masks with gdal_viewshed and then merged them together to make that picture.
That picture or the docs should maybe be updated to reflect a more common scenario with better description. File a ticket and attach some language and pictures to it as you start playing with it and we can merge it.
Thanks,
Howard
