[gdal-dev] Removal of API_PROXY mechanism: objections?
Kurt Schwehr
schwehr at gmail.com
Thu May 7 11:59:42 PDT 2020
+1 for removing
On Thu, May 7, 2020 at 11:53 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi,
> https://github.com/OSGeo/gdal/pull/2489 kills the API_PROXY mechanism,
> which removes 7820 lines of code. Anyone objects ?
> Note: if you have no idea what this is about, then it means you never used
> that stuff since it couldn't be used just accidentally like other
> functionalities. I'm not aware of anyone having used that ever (except me
> when developing it long time ago)
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200507/a5c6717e/attachment.html>
