[gdal-dev] Wrong GDAL VersionInfo
Pedro Venâncio pedrongvenancio at gmail.com
Thu May 7 14:38:27 PDT 2020
Hi Even,
You're right, I hadn't python3-gdal-dev package installed. After install it
and run gdal-dev-py3-env, version become correct in OSGeo4W Shell
gdal.VersionInfo()
'3020000'
Should not python3-gdal-dev package be installed by default with gdal-dev?
However, I was trying it inside QGIS, in Python console, and there the
output is still '3000400', both in qgis-rel-dev (3.12.2) and qgis-dev
(3.13.0-master), compiled against GDAL 3.2.0dev.
I tried to change in qgis-rel-dev-g7.bat
call gdal-dev-env.bat
to
call gdal-dev-py3-env.bat
but without success. It seems that something more needs to be changed.
Do you think I should open a ticket in QGIS or OSGeo4W tracker?
Thanks again!
Best regards,
Pedro
Even Rouault <even.rouault at spatialys.com> escreveu no dia quinta, 7/05/2020
à(s) 18:44:
> On jeudi 7 mai 2020 18:29:02 CEST Pedro Venâncio wrote:
> > Hi all,
> > I'm seeing that gdal 3.2.0dev is giving a wrong gdal.VersionInfo()
> output:
> > '3000400'.
> > Anyone confirm?
> You're probably not using the Python module corresponding to master. Have
> you intalled the python3-gdal-dev package and run gdal-dev-py3-env.bat to
> set the appropriate environment ? (didn't try. no Windows VM started. Just
> looking at the content of
> https://download.osgeo.org/osgeo4w/x86_64/release/gdal/gdal-dev/python3-gdal-dev/python3-gdal-dev-3.2.0-9.tar.bz2
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200507/6e681fe7/attachment.html>
