[gdal-dev] Setting up a source resolution for TMS
Even Rouault
even.rouault at spatialys.com
Sat May 16 04:29:23 PDT 2020
On samedi 16 mai 2020 00:51:27 CEST Denis Rykov wrote:
> Great! Thank you. I also found out that the same result can be achieved
> with gdalwarp and "-ovr" option.
Yes, uses the same mechanism underneath
> Is there any advantages of using gdalwarp instead of gdal_translate to
> convert partial extent of TMS service to an image if reprojection is not
> required?
gdal_translate is generally faster than gdalwarp for operations that can be done
by both.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200516/23380bcd/attachment.html>
