[gdal-dev] self-compiled gdal linking to old already-remove proj libs
Andreas Neumann
a.neumann at carto.net
Sat May 16 10:18:27 PDT 2020
Thank you both Jeff and Even.
Yes, apparently libspatialite was also self-compiled. I can renew that.
That was the one linking against non-existant old libproj.
For libgeotiff I used the packaged one, which links against
/usr/lib/x86_64-linux-gnu/libproj.so.15
Is it a problem if libgeotiff links against a different libproj than
gdal? Should I also self-compile libgeotiff?
Thanks for your help! It helps me to solve the compile and link issues.
Andreas
Am 16.05.20 um 16:12 schrieb Jeff McKenna:
> Hi Andreas,
> I have been in your exact situation before. What's happening is that
> a GDAL dependency lib is still pointing to the old libproj version.
> Please check:
> ldd /usr/local/lib/libgdal.so | grep geotiff
> and then ldd to the exact path of the geotiff lib, and look at
> which libproj is linked to
> and do the same for spatialite:
> ldd /usr/local/lib/libgdal.so | grep spatialite
> and then ldd to the exact path of the spatialite lib, and look at
> I bet that is what happening in your case also. If I am correct, then
> you have to recompile those libraries and point to PROJ in /usr/local/
> Cheers from across the ocean.
> -jeff
