[gdal-dev] Finnish KKJ and MapInfo MIF with GDAL 3.1
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Mon May 18 04:17:52 PDT 2020
This command
ogr2ogr -f "MapInfo file" -s_srs epsg:3067 -t_srs epsg:2393 2393.mif tm35.jml
writes into MIF
CoordSys Earth Projection 8, 104, "m", 27, 0, 1, 3500000, 0
ogrinfo shows
ogrinfo 2393.mif -al -so
INFO: Open of `2393.mif'
      using driver `MapInfo File' successful.
Layer name: 2393
Geometry: Unknown (any)
Feature Count: 3
Extent: (3284260.027390, 6962722.914217) - (3284610.369420, 6962941.953889)
Layer SRS WKT:
PROJCRS["unnamed",
    BASEGEOGCRS["unnamed",
        DATUM["World Geodetic System 1984",
            ELLIPSOID["WGS 84",6378137,298.257223563,
                LENGTHUNIT["metre",1,
                    ID["EPSG",9001]]]],
        PRIMEM["Greenwich",0,
            ANGLEUNIT["degree",0.0174532925199433,
                ID["EPSG",9122]]]],
    CONVERSION["unnamed",
        METHOD["Transverse Mercator",
            ID["EPSG",9807]],
        PARAMETER["Latitude of natural origin",0,
            ANGLEUNIT["degree",0.0174532925199433],
            ID["EPSG",8801]],
        PARAMETER["Longitude of natural origin",27,
            ID["EPSG",8802]],
        PARAMETER["Scale factor at natural origin",1,
            SCALEUNIT["unity",1],
            ID["EPSG",8805]],
        PARAMETER["False easting",3500000,
            LENGTHUNIT["metre",1],
            ID["EPSG",8806]],
        PARAMETER["False northing",0,
            ID["EPSG",8807]]],
    CS[Cartesian,2],
        AXIS["easting",east,
            ORDER[1],
                ID["EPSG",9001]]],
        AXIS["northing",north,
            ORDER[2],
                ID["EPSG",9001]]]]
Data axis to CRS axis mapping: 1,2
When I convert this data back into EPSG:3067 the coordinates are shifted by a hundred meters probably because what was called towgs84 parameters are not applied. Parameters appear in the mitab source code https://github.com/OSGeo/gdal/blob/master/gdal/ogr/ogrsf_frmts/mitab/mitab_spatialref.cpp#L251
{ 0,    1016,"Finnish_KKJ",                4, -96.062, -82.428, -121.754, -4.801, -0.345, 1.376, 1.496, 0},
I tried to fix the MIF by changing the CoordSys line into
CoordSys Earth Projection 24, 1016, "m", 27, 0, 1, 3500000, 0
that is to my knowledge what MapInfo itself is using but that does not work at all with GDAL
ogr2ogr -f "jml" -t_srs epsg:3067 2393_alt_from_mif.jml 2393_alt.mif
ERROR 1: PROJ: proj_as_proj_string: Unsupported conversion method: Transverse_Mercator_MapInfo_24
ERROR 6: Cannot find coordinate operations from `PROJCRS["unnamed",BASEGEOGCRS["unnamed",DATUM["Finnish_KKJ",ELLIPSOID["International 1924",6378388,297,LENGTHUNIT["metre",1,ID["EPSG",9001]]]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433,ID["EPSG",9122]]]],CONVERSION["unnamed",METHOD["Transverse_Mercator_MapInfo_24"],PARAMETER["latitude_of_origin",0,ANGLEUNIT["degree",0.0174532925199433,ID["EPSG",9122]]],PARAMETER["central_meridian",27,ANGLEUNIT["degree",0.0174532925199433,ID["EPSG",9122]]],PARAMETER["scale_factor",1,SCALEUNIT["unity",1,ID["EPSG",9201]]],PARAMETER["false_easting",3500000,LENGTHUNIT["metre",1,ID["EPSG",9001]]],PARAMETER["false_northing",0,LENGTHUNIT["metre",1,ID["EPSG",9001]]]],CS[Cartesian,2],AXIS["easting",east,ORDER[1],LENGTHUNIT["metre",1,ID["EPSG",9001]]],AXIS["northing",north,ORDER[2],LENGTHUNIT["metre",1,ID["EPSG",9001]]]]' to `EPSG:3067'
ERROR 1: Failed to create coordinate transformation between the
following coordinate systems.  This may be because they
are not transformable.
Is there something that I could do for making the conversion to round-trip?
-Jukka Rahkonen-
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200518/156e7953/attachment-0001.html>
