[gdal-dev] Python/Java GDAL - How to estimate the geo coordinates and width / height without warping dataset?
Pham Huu Bang
a09550 at gmail.com
Tue May 19 09:36:53 PDT 2020
@Even Rouault <even.rouault at spatialys.com>
Unfortunately, this method is not enough to solve my problem as I *also
have a given geo X, Y resolutions *in target CRS (EPSG:4326) as input.
Below is what I've with Python GDAL:
src_ds = gdal.GetDriverByName("VRT").Create("", 1830, 1830)
src_ds.SetGeoTransform([600000.000, 60, 0, 5900040, 0, -60])
// source CRS EPSG:32632
src_srs = osr.SpatialReference()
src_srs.ImportFromEPSG(32632)
src_wkt = src_srs.ExportToWkt()
// destination CRS EPSG:4326
dst_srs = osr.SpatialReference()
dst_srs.ImportFromEPSG(4326)
dst_wkt = dst_srs.ExportToWkt()
// This method doesn't have the possibility to add the given geo X, Y
resolutions in EPSG:4326 (!)
dst_ds = gdal.AutoCreateWarpedVRT(src_ds,
src_wkt,
dst_wkt,
gdal.GRA_NearestNeighbour,
0.125)
On Tue, 19 May 2020 at 18:14, Even Rouault <even.rouault at spatialys.com>
wrote:
> On mardi 19 mai 2020 12:01:58 CEST Frank Warmerdam wrote:
> > Pham,
> > I have sometimes taken the approach of doing a "gdalwarp to VRT" which
> > creates the configuration of the target dataset in VRT format, but does
> not
> > actually resample any imagery. The you can open the VRT and query it's
> > configuration. There are also lower level apis to get this information
> but
> > they are not normally exposed through SWIG in Java, Python, etc as far
> as I
> > know.
> gdal.AutoCreateWarpedVRT() is available in Java bindings:
> https://gdal.org/java/org/gdal/gdal/gdal.html
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200519/15d71253/attachment.html>
