[gdal-dev] Updated GDAL and PROJ, now certain datasets crash when calling GetGeoTransform
Even Rouault
even.rouault at spatialys.com
Wed May 20 08:07:50 PDT 2020
On mercredi 20 mai 2020 14:47:00 CEST Craig Delancy wrote:
> I already clean the solution before rebuilding, as I can't get a successful
> build without doing this. Here is an example that causes the crash.
(Readding the list without the download URL)
Works fine for me with gdalinfo, or with just GetGeoTransform() with the
Python bindings.
I'd suspect something wrong in your configuration. Check that your GDAL
build links against a single PROJ lib for example
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200520/077e65fa/attachment-0001.html>
