[gdal-dev] Conflict between scipy/pypocketfft and GDAL/ECW
Even Rouault
even.rouault at spatialys.com
Thu May 21 10:54:11 PDT 2020
Sean,
> I've run into an apparent conflict between pypocketfft, the basis for
> scipy.fft introduced in scipy 1.4.0, and GDAL 3.1.0 built with the ECWJP2
> SDK version 5.5. I'm wondering if anyone has seen this and found a solution
> other than downgrading scipy to 1.3.2?
I suspect this is another manifestation of the issue raised in
https://github.com/OSGeo/gdal/issues/2394 , that is that the ECW SDK 5.5 on Linux
is statically linked against a libstdc++ implementation, incompatible of the one of
the system, that other libraries may use. However it is not obvious to me that scipy
contains C++ code.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200521/2dc29e27/attachment.html>
